I can not connect to mysql
Fatal error : Uncaught mysqli_sql_exception: Unable to find the socket transport “unix” - did you forget to enable it when you configured PHP? in /home/vol7_4/infinityfree.com/if0_34679847/htdocs/kuran/get_favorites.php:7 Stack trace: #0 /home/vol7_4/infinityfree.com/if0_34679847/htdocs/kuran/get_favorites.php(7): mysqli->__construct(‘localhost’, ‘emr13amiirxyz_k…’, ‘emr13amiirxyz_k…’, ‘emr13amiirxyz_k…’) #1 {main} thrown in /home/vol7_4/infinityfree.com/if0_34679847/htdocs/kuran/get_favorites.php on line 7
i can not connect to mysql using mysqli and pdo. chatgpt says find php.ini file an make some changes but i con not find etc/php70/php.ini file, only i can see is htdocs directory.
Hi and welcome to the forum!
what an unnecessary post. it doesn’t solve any problem
It would if you actually read it. You are using localhost, which is incorrect.
The rest of the construct() function looks incorrect as well. Please make sure you are getting the information from the client area / control panel, not just making it up.
sorry, you are right
