my website: https://chillinetwork.com/
my issuse : i am using cloudflare for ssl but it is showing active on cloudflare cpanel but it is not working on domain and when i tried to certificate details it shows issuer is ifastnet but is CloudFlare Inc ECC CA-2 is there is any way to change my issuer from ifastnet to cloudflare. admin or any community member please help me cause i read so many forums about cloudflare ssl but nothing worked
screenshot for more details:
Magnus
August 5, 2019, 2:37pm
2
SSL Certificates can take up to 24 hours to Issue.
my ssl is active from last 3 days on cloudflare cpanel but it is not active on website
Magnus
August 5, 2019, 2:41pm
5
Did you use the cPanel integration?
yes i used ssl/tls first then i used cloudflare
Magnus
August 5, 2019, 2:43pm
7
If you go to your Cloudflare Dasboard, what does it say for „this settings was last changed … ago“. As in … being the time.
Magnus
August 5, 2019, 2:45pm
9
Your website resolves in a 404 error for me.
Magnus
August 5, 2019, 2:48pm
10
Though, I would recommend you change the SSL Settings to „Full“ and then wait 24hours to become active.
it is showing all details about my certificate on sslchecker but it is working on my website i don’t know why
i don’t any thing about root1.
“Root 1” is the root certificate. You can’t install it on free hosting, and you shouldn’t worry about it.
Magnus
August 5, 2019, 2:53pm
15
Okay, then I see what the problem is. This Issue is like when domains do not directly work. Please try clearing cookies, flushing DNS etc.
ssl is not working my all devices not only on my computer
Magnus
August 5, 2019, 2:58pm
17
All your devices probably use the same (slow) DNS Server. Try flushing your DNS, clearing Cache and/or changing your DNS to a faster service.
i changed my dns to 1.1.1.1 and now it is showing
Magnus
August 5, 2019, 3:06pm
19
Have you added files to your website?
yes i am using wordpress on my site
