I am facing Problem
![Screenshot_2024-12-21-04-06-58-919_com.android.chrome|225x500]
(upload://ypINCYXZuDB74H8Cgztz7YjDpvp.jpeg)
( Dangerous site
Attackers on the site you tried visiting might trick you into installing software or revealing things like your passwords, phone, or credit card numbers. Chrome strongly recommends going back to safety. [Learn more about this warning)
Turn on enhanced protection to get Chrome’s highest level of security
This is something you’ll have to take up with Google.
While I would suggest the same thing EdwardHamHam said, when I went past the Deceptive Site Ahead screen on a secured Macbook, I seen a no-label Login screen, with the input boxes bleeding off the space. Google doesn’t like seeing that.
It’s happened because you miss configured site SSL certificate
Delete your SSL certificate and request for new one I will recommend zero SSL because it’s free or Google trusted and its helps to rank your site
Then configure your SSL certificate carefully change your DNS name or your private key And certificate you can also click on automatic installation
Optional
Use tokens for API request
