I already build my website and I use freenom for zanshan.ml
**My website URL is:zanshan.ml
**What I’m seeing is: I already build my website and the domain come from freenom but sometime l go on my site it somehow transfer me to infinity free ,it seen like my web was hijack. Please do not do that
**I’m using this software
Additional information:
it seems like your project files isn’t in htdocs folder ,
as this is infinity free (coming soon) default site , it shows when your htdocs is empty or it doesn’t contain index file i guess
when i use ip address to go on my site it also automatically transfer me to here
My file was in the wordpress folder
please help me
look . open Monsta FTP then you’d see some folders , check if there’s a folder with same name as your domain ,
i exist enter it then enter htdocs folder and make sure that this folder contain all your project files . else : the admin will answer you to figure out the problem and fix it
Completing who has said @anon23072276, if the project files aren’t in the htdocs, you need to move them on htdocs, and go to where your website is to see it.
If you don’t want to see the InfinityFree index page delete the index2.html file inside of the htdocs folder.
