http://events-zone.rf.gd/?i=1
N/A
When it is http, it works fine, however on https, it doesn’t display well, like if the css was gone, could you tell me what did I do wrong please? https://imgur.com/DD3fxNk.png
For this one I did not request a SSL certificate but on a previous one, it did act like if it removed css (SSL certificate was requested for that new link btw)
Hey, yes, I did that on the old URL, and when it was issued, then it did act like if the css was gone. I’ll install it again on that new link so you can see.
Check the link now please, you’ll see SSL certificate is added but it’ll show like if css isn’t present anymore, works still for http though
Mixed content!
When HTTPS is used, all resources should be requested via the HTTPS protocol and not via HTTP.
Since you are using a CMS we don’t actually know, I don’t know if there is an option to change URL from HTTP to HTTPS on the admin area of it (if it also exists) or you have to do it via the database, though the CMS website doesn’t work anymore, so I don’t know if you can contact the developer in any way as well.
The weird part is that in the past it worked fine, I guess in the worst case I stick back to http, but in the past it didn’t cause any issue (?)
No, I don’t think so, I went through all settings and I found nothing of such
The only thing I can tell is that you don’t have a secure browser in the past.
Really?
Can you at least share what CMS you’re using right now so that we can check?
It was edge too
Really?
Sure, it’s on softaculous, it’s called CSZ CMS, it’s a downloadable template
I don’t really think that using a CMS that wasn’t updated in the last 3 years is a good idea…
As a bonus, their official site is just down. I recommend you to migrate to something newer and safer.
