Chrome: ERR_CONNECTION_TIMED_OUT és alá curl: (28) Connection timed out after 10002 milliseconds
The website times out on both my work network and mobile data. The hosting account is Active. DNS resolves to 185.27.134.213, which matches the Website IP in the dashboard. A direct HTTPS test using curl --resolve also timed out after 10 seconds. The hosting volume is vol2_6.
Could you check whether there is a connectivity issue affecting port 443 on this IP?
Your site’s IP, 185.27.134.213, is listed in an open incident on the status page. The incident covers websites on several IPs that are unreachable. It was updated at 14:39 UTC to include 185.27.134.213, which matches the timeout you’re seeing. The account lookup also shows that this IP is the one assigned to your giriczkarpitos site.
Here is the incident:
Your own tests already point to a problem on the server side. The timeout happens on two networks, and curl --resolve times out too. That isn’t something you can fix from your account or site settings, and the incident is where updates will be posted.
