Http to https general settings fail
smmpanelmacedonia.com
This page isn’t working
smmpanelmacedonia.com redirected you too many times.
i followed some threads on how to fix but they say to go to functions.php in cpanel to switch back to http but i cant find it anywhere. Please help me switch to http via File manager. Thank you
only happens in wp-admin
Read this…
i dont have issue with SSL, only with Settings General option which i changed from http to https. now i cant access wp-admin.
SSL is working fine with Cloudflare.
Read carefully
To regain access to your WordPress admin area, you can do the following:
  1. Login to your client area, find your hosting account, click Manage and then go click Control Panel.
  2. Go to phpMyAdmin, find your WordPress database and click Connect Now.
  3. Find the table with the name ending with _options and click on the name.
  4. Find the rows with the column option_name matching siteurl and home. These should be the first two in the list, but you can use the Search function if you can’t find them.
  5. Double click the value in the option_value column, and change the start of the URL from https:// to http://.
thank you it worked :slight_smile:
