(epiz_30462986)
( This page isn’t working
mowaredin.epizy.com is currently unable to handle this request.
HTTP ERROR 500)
(how to solve that)
(epiz_30462986)
HTTP ERROR 500)
(how to solve that)
A HTTP ERROR 500 means that your PHP code crashed. To fix it, you need to debug the issue and solve whatever is causing this.
The first step towards that is to get the actual error message. This article can help with that:
user = epiz_30462986
Pass = HIDDEN BY MOD
url=
i can not fix .
so , you can fix it
*********'s)ok
how to solve
Code… please
We cannot tell you what is wrong if you tell us things that do not help. If you want a solution please tell us…
can you take my user & pass ?
to do this
cause i can not fix this
No. I do not have access to the system, only Admin does. And he is not going to give you free tech support. Even if you buy paid hosting, they will not do things for you.
If you want a solution, you need to provide us with enough information so we can give you an answer.
If you don’t want to give us the information we require, then there is nothing anyone here can do to help you. You can check out this article that tells you pretty much exactly what to do though
