.htaccess Error please help! [ERROR 404]
Hello there. I made the SSL settings in infinity free, but now I want it to redirect http directly to https from my .htaccess file. I tried a lot of code but after doing all of them I click somewhere and it gives 404 error please help me.
RewriteEngine On
RewriteRule ^(.*)$ index.php?/$1 [L]
this is the only working .htaccess code. Here it redirects to http. Even if I try all https or redirect codes, they all give 404 errors.
Follow this guide:
not working in this code
Use this code:
RewriteEngine On
RewriteCond %{HTTP:X-Forwarded-Proto} !https [OR]
RewriteCond %{HTTPS} off
Then clear your cache. If it is still not working, share your domain name and the entire contents of your .htaccess file.
I’m sorry dude, but this doesn’t work, I tried many times and even deleted and reopened your file.
Then follow the rest of my post:
Domain name : flwus.com
And…
.htacces
RewriteEngine On
Its working, so you need to clear your cache or try a different browser. Your ISP may also be caching it, so try using a different device.
Dude, the homepage works, yes, but when I click on one of the categories, it gives a 404 error, I tried it from other devices and browsers.
I have no idea how to solve
Oh, I should have re-read the title, sorry.
Your .htaccess code is file, a 404 error means the page cannot be found. Remember that names must be excatly the same!
So. “hello.html” IS NOT THE SAME AS “Hello.html”
I’ve been looking, but I can’t find such a faulty file.
Its not one file, its all your files. Your links lead to filenames with no extensions that do not exist. Please screenshot the filemanager.
Which links return a 404 error? I checked https://flwus.com/ but there is only one landing page there as far as I can tell. I don’t see the categories you are referring to.
I think he means all the hyperlinks in the navbar
Which navbar? I only see a page saying “Coming Soon”, with no links or buttons on the page.
He changed it, it looked completely different before.
Oh I’m sorry. The site wasn’t like that yesterday, I changed it, now I’m going to do it again like yesterday.
