.htaccess caused 404 erroe except index
how problem occurred
site used to run perfectly until I made some changes to force http traffic to https and for that reason i had to make change in the .htacces file.
unaware of the root directory, I first changed the one that come default with infinityfree
some error massage popped up while saving so I deleted the .htaccess in root directory hoping to recreate it freshly afterwards.
Problem:
Before doing anything with my .htacces file the site home page used to load like https://anisuki.rf.gd/home
after the issue every other pages showing 404 error and every the url needs to show extension otherwise its not loading up (e.g. https://anisuki.rf.gd/home.php)
what im looking help for:
  1. fix the .htaccess in root dir (and how i can recreate it without messing it up)
  2. other pages except index to load
  3. remove the url extension (e.g. /home.php to /home )
since im using custom made player its a hassle to change it all up just to specify the link extension.
here’s the code i used in htdocs/.htaccess to force traffic to https
RewriteEngine On
RewriteCond %{HTTP:X-Forwarded-Proto} !https
RewriteCond %{HTTPS} off
RewriteCond %{HTTP:CF-Visitor} !{“scheme”:“https”}
I’m not seeing any 404 errors
