Can I have a step-by-step tutorial on how to host my own phpBB forum?
Hello there,
You can either use our one-click automatic installer or manually installing phpBB via FTP.
If you want to use our one-click auto installer:
Go to the Control Panel → Softaculous → Search for phpBB → Fill up the fields with necessary stuff (Leave the “Directory” field blank if you want to install it on your root) and Install.
If you want to manually install phpBB, please refer here:
