There has been a critical error on this website. Please check your site admin email inbox for instructions. If you continue to have problems, please try the support forums .
Learn more about troubleshooting WordPress.
Hi and welcome to the forum! Maybe your WordPress installation is corrupted:
WordPress frequently releases updates, which you can install through WordPress’ admin interface. Usually, this works without a hitch. But with some (big) upgrades, the upgrade fails half way and leaves you with a broken website.
Fortunately, you can still fix your website without any data loss, and this article tells you how to do that.
Download a fresh copy of WordPress
First of all, you will need to download a fresh copy of WordPress. You can download this from the official WordPress website…
If it didn’t work, maybe a plugin or a theme is corrupted:
WordPress supports installing and updating plugins and themes from the official store right through the WordPress admin interface. However, after trying to install or update a large plugin (like WooCommerce) or theme, you may encounter an error like this:
Installation failed: There has been a critical error on your website. Please check your site admin email inbox for instructions. Learn more about debugging in WordPress.
This error means that the installation process crashed, and may have l…
