How to shift DNS to Cloudflare?
Hi, I want my site DNS (ns1.epizy.com & ns2.epizy.com) to be shifted to Cloudflare. How do I do that? I have already activated Cloudflare (from vPanel and personally).
Signup on Cloudflare, change your nameservers to the ones provided by Cloudflare and then your DNS will already be there.
I cannot find the nameservers. How to get them? I have signed up on Cloudflare.
Are you using a free domain?
Nope. I bought a domain
classroomonline.co.in
You can change your Nameservers via your Domain Provider’s control your panel.
I know that but where do i find the nameservers in cloudflare??
It shows this…
Manually signup for cloudflare
done. actually i did it many days ago tho…
Just be careful because I’ve used cloudflare and it has crashed my websites . Make a back-up before doing anything
Hmm, you should try to re-add your domain to cloudflare, then change your nameservers to which they want you to?
Adding Cloudflare through cpanel will leave your site DNS corrupted somehow.
@anon10052063 i literally dont have anything…
@anon19508339 trying it…
Site down rn
ok. lets see. thanks @anon19508339
May i see your DNS settings in your cloudflare?
wait a bit it still didn’t connect to cloudflare but dns is active. odd.
