How to set https?
epiz_27793214
Can’t set HTTPS
I’m trying to set HTTPS to my web. I generated a ket/CSR in my control Panel under SSL section.
Then in Free SSL Certificates section I generated a free ssl But I have the following err message
No SSL certificate was found
I tried using zeroSSL but I can’t verify the domain (using the cname or uploading the pki file)
Thanks for any help !
Just use Free SSL Tool from InfinityFree here: https://app.infinityfree.net/ssls
Click the button “Request SSL Certificate” to the up and right from that message to - you know - get the SSL certificate.
Also, you don’t need to generate a key and CSR from the control panel. For the exact steps, please see this guide:
