I want to remove the POWERED BY VANILLA logo on the bottom of a vanilla forum page (look here in the footer: http://casmat.ga/forum) I also want to change to copyright to my company’s copyright. Is there any way to do this… Here is a old topic on the vanilla forum archive, but It is confusing :https://open.vanillaforums.com/discussion/20762/can-i-remove-vanilla-copyright-footer (Removing the logo and editing the copyright is allowed in the license.)
Well, this kind of seams like something to ask their community, but this part does make sense from the fourm link you provided. Just change the text from “Powered By Vanilla” or something else, or add the CSS line.
In the theme should be a file at views/default.master.tpl. At the end of that file is the HTML/PHP code which renders the theme. You can edit that code to show whatever you want.
i think your forum is broken because when i try registering it says ths
and also thre is an annoying thing in vanilla that you can’t turn off called ‘why u want to join’ and it doesnt work but there is an addon to remove it. i recommend u get it so people can register
just download ‘joinreasonoptout.zip’ and upload the folder in there to /plugins/ and go to your plugins section in the dashboard and install it and people can now register
also fix your captcha
