How to put a project to work with codeigniter 4 with Database
Help, I need to upload a project in codeigniter 4 and I don’t know how to do it, I’m a novice at this and I would like to be explained in detail and in steps, there is a tutorial in this forum but I can’t understand it correctly. Please help
  • Upload all files using FTP.
  • Create a new database from vPanel.
  • Export database from localhost phpmyadmin
  • Upload exported database file in infinityfree vPanel.
    Simple… Feel free to reply if you need more help.
to upload the FTP files is using the file manager?
and what about the configuration in the codeigniter 4 folders
Upload all your files in the htdocs folder!
Umm, update database details in your .env file? Sorry, I am a noob with laravel. Just know PHP for now :stuck_out_tongue_closed_eyes:
Do you know why I get an error when uploading several files at the same time?
What should I do to upload all the files at the same time?
it doesn’t even leave me with a .zip
Please use filezilla for this purpose. Since, you’re a novice, here’s a guide:
