My website URL is: http://ack.fanclub.rocks/
What I’m seeing is: http://ack.fanclub.rocks/index.php
Additional information: When you first visit the URL, it looks fine. But when you click the “Translate” button it adds “/index.php” to the URL.
Thanks, that will probably work. Unfortunately I’m getting this error now that I deleted the index.php and uploaded the new one:
“Connection failed: No such file or directory”
You could only edit it with monstaFTP
Please check your database configuration, database hostname, etc.
Thanks, you are right I should have edited in Monsta. The problem was I forgot to change the database credentials after I had changed them for testing on XAMPP on my pc.
