Not_Me
February 27, 2021, 4:52am
1
There are three methods.
Use Cloudflare free SSL (Use Flexible SSL only.)
Get free SSL in the client area
Buy SSL from godaddy.com or any other service
I’m gonna tell you only about two because I didn’t use GoDaddy.
1 Method (You need your own domain ofc)
Register at Cloudflare, if you didn’t do this before
Click the button “Add Site”
Verify your domain.
Change SSL to Flexible.
Add InfinityFree nameservers (I think you know why.)
Enjoy!
2 Method (You can use InfinityFree subdomains, but I will write only for custom domains)
Get to your client area, if you didn’t do that before
Get to the tab “Free SSL Certificates”
Click “Add SSL Domain”
Choose Custom Domain (If you have that.)
Set up DNS that you’re given.
Press Request SSL
Do everything that it says.
Wait until it’s done
Done!
KangJL
February 27, 2021, 5:46am
2
Another way will be to use InfinityFree SSL tool to install SSL cert. Then add the custom domain to CloudFlare. Last step will be to change SSL mode to full or full(strict) within CF. No .htaccess modification will be needed. Take note full(strict) mode cannot be used on self-signed cert
For those who find renewing SSL cert every 3 mths a hassle, get a self-signed cert from
https://www.selfsignedcertificate.com/
This method will only work with custom domain.
Hello,
I have an easier way. And please don’t use and self signed certificate cause any browser don’t trusts an self signed certificate. You can read this -
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that. If you would rather watch a video, scroll down to the bottom of this article. Installing an...
Or…
Watch this tutorial and you will have a perfect certificate.
Regards,
TurboX World Technology
https://www.turboxworldtechnology.xyz/
Yes, I answered a post about SSL, here: SSL free - #42 by Casmat
No, It is not. All domains of all TLDs will work. See my own domain I am using an .xyz domain and same ssl
1st Method, How to add InfinityFree nameservers? where to add ?
Through the domain provider you are using.
