hello i just installed flarum and i redirected forum.mydomain.com to my ip on cloudflare but when i want to access to my website (forum.mydomain.com ) it make this error
thank you !
KangJL
February 13, 2022, 3:24pm
2
What SSL mode are you using on CloudFlare (flexible, full or strict)?
If it is full or strict, you will need self-signed or SSL cert installed in the VPanel.
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
This article only applies to custom domains
Free subdomains (like your…
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your website. This article describes how to do that.
If you would rather watch a video, scroll down to the bottom of this article.
Installing an SSL certificate
The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get your SSL certificate from a certificate vendor of your choice. InfinityFree also provides free SSL certificates in the client …
KangJL
February 13, 2022, 3:33pm
4
Did you install any self-signed or SSL cert in the Vpanel of the hosting account?
If not, you need to do this
KangJL:
If you’re using free hosting with your own domain or a subdomain, you’ll want to make this website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site. Step 1: Set up the domain on your hosting account The first thing to do is to set up the domain name on your hosting account. When you create a new hosting ac…
In order to get a padlock in the address bar in your website, you need to install an SSL certificate on your account. This article describes how to do that. Installing an SSL certificate The first step to install an SSL certificate is of course to get the SSL certificate. You will need to get this SSL certificate at a certificate vendor of your choice. InfinityFree also provides free SSL certificates from the client area , but you are free to use any other recognized SSL vendor too. If you al…
cloudflare already give me a certificate and that what i’m using on my website and its working fine but when i use my subdomain forum. it make that error
KangJL
February 13, 2022, 3:38pm
6
This will work well for flexible mode only.
If you want full mode to work, you need minimally a self-signed cert installed for domain/subdomain on hosting account as well.
how do i get a self-signed certificate?
KangJL
February 13, 2022, 3:41pm
8
i dont know but it told me The selected custom domain is already in use and cannot be added to an account. but its not mydomain.com its forum.mydomain.com
KangJL
February 13, 2022, 4:03pm
10
You are supposed to get your self-signed or SSL cert from the client area.
I am assuming your subdomain is already added to the hosting account…
KangJL
February 13, 2022, 4:06pm
12
You still do not get it.
What about the subdomain?
i dont have any ssl for it.
and yeah XD i still not get it
duh , create a new self-signed cert for the forum domain.
KangJL
February 13, 2022, 4:08pm
15
If you do not have self-signed or SSL cert for subdomain, do you think it can work?
oh ok i found the problem XD thank you
system
Closed
February 20, 2022, 4:10pm
17
