mcphc01
February 26, 2024, 3:18pm
1
Waiting to retry…
Status: Connection attempt failed with “EAI_NONAME - Neither nodename nor servname provided, or not known”.
This error appears in Filezilla app when i click the quickconnect button
Oxy
February 26, 2024, 3:30pm
2
Hi and welcome to the forum
You can work around by using the FTP hostname ftp.epizy.com or using the IP address 185.27.134.11
Being able to access your hosting account over FTP is very important to manage your website files. However, there are reason why you may have trouble connecting to the FTP service. This article explains a few things you can try to fix your FTP connection.
Login to your control panel
After your account has been created, or reactivated after a suspension, you may need to login to the hosting control panel once to enable FTP access to your account.
You can login to the control panel by logging in…
mcphc01
February 26, 2024, 3:34pm
3
Working, Thank you so much
Oxy
February 26, 2024, 3:40pm
4
Thanks for the feedback - we’re glad it worked!
For some reason ftpupload.net is not resolving from your side (maybe some AV/firewall or xy-block).
Good luck with your future work
system
Closed
March 4, 2024, 3:40pm
5
