How to delete a site.pro installation and restore your previous website
Accidentally setup the Site.Pro sitebuilder on your domain? Don’t worry, it’s easy to remove the sitebuilder and restore your old website.
Common Use Case: Most commonly, users (like you!) will install WordPress, then decide to see what the sitebuilder has to offer. Deciding that WordPress is better for them, confusion occurs as deleting the sitebuilder account does not restore the WordPress installation!
Before Getting Started
Before continuing, let’s make sure that this guide will work for you. The following MUST be true to continue!
Removing Site.Pro is really easy!
Step 1
Open the file manager from the account dashboard
  1. Go to Log in to your account - InfinityFree and select your account, then find your domain and select the “Manage” button.
  1. Select the orange “File Manager” button
Step 2
  1. Delete the index.php file from the account
Step 3
  1. Rename the spb_index.php file to index.php and click “ok”
Step 4
Test and make sure it works! Load your domain name and see if your original site appears!
Still not working? Open a new topic in Hosting Support
Uploaded index.html to htdocs folder. Not being seen
My website is not working
Wordpress + cant see my site and wp-admin
Help Needed to Publish My Website
The site is not displayed after domain recovery
I get this when I try to access my https webpage
Website 404 erorr
Https://morganfinance.epizy.com/
How to disable site builder pro. had a website made with wordpress now its showing coming soon plz h
Page won't load - says Our Website is Coming Soon!
Webpage files won't appear
An index.php file from another website was found
WordPress
Why my web-site did not works?
Unwanted site.Pro
How to delete site.pro website and make google sites my default
Created a new account I cannot login to wordpress wp-admin
Unable to log in into wp-admin
Website URL talko.rf.gd
All files uploaded to website, still get "our website is coming soon" screen
Upload Fails on All Websites — Even Basic HTML
After five days I cannot view my site on the web
My content not allowed
Recovering of files and also please make it of wordpress
Even after 72 hours, the website is still not online
I waited more than 72 hours
The site stopped opening
Can't use my html code anymore bc of site builder
Website issues
Error
Redirecting to "defaultsite"
How should i publish with wordpress and cancel site.pro builder
Why can't I launch my website via HTTPS?
Regarding Website
I think Infinity Free is bugged
Thanks Mannn. Great Appreciation For You Brother. Helped Me Alot
I think this step needs to be changed again.
User would goto their InfinityFree account, then select → Manage next to the domain, then select the orange File Manager button.
You are right, it has been updated.
(Thank you for noticing)
Hello,
I tried to follow your instructions but the site is not accesible (step before getting started).
Our site has a freesite.online extension and we saw that it was suspended, do you think that we can access our site again if we wait ?
Another problem is that we overwrote our site with a site.pro to try and follow this tutorial. Is there any backup of our older website by any chance ?
thank you
That’s the idea, yes. If you would like to discuss the status of freesite.online domain being down, please ask your question in the dedicated topic.
That’s what the spb_index.php is about. The only thing Site.Pro does is move your existing index.php file out of the way and add their own files. All your other website files will not be touched and your website should just work when you move the index.php file back in place.
Hello, unfortunately we do not have the spb_index.php file in the file manager. Do you have any idea why ?
Did your website have an index.php file to begin with?
If there is no original index.php, then the index.php file will not be renamed to spb_index.php.
If you had an index.html file instead, it will still be there. Same with a home.php or a file with another name. And if there was no website to begin with, then of course you cannot restore the previous website.
@Greenreader9 I noticed that the button to delete the Site.Pro entry is no longer a thing, so I had hidden the step.
I also made a major oopsie updating the guide, most of the images disappeared! I recreated the images, please don’t be mad at me!
I commented everything out in case edits need to be reverted.
