How To Connect GoDaddy Domain To InfinityFree
Hi,good day! I have just added my new custom domain in InifnityFree. I can’t access my wordpress site and for some reason my IP address is Red did I do something wrong
IP address is correct for me.
Client area probably have old DNS data cached or is simply having issues checking it.
Meanwhile, please share your actual error message so that we can check what is really the error instead of you assumimg an issue first then only sharing what you think is relevant which might get you into the wrong direction.
Here, I can’t access my admin word press
You need to get an SSL certificate. Custom domains don’t get them automatically.
Domain is working from my end (U.S. East)
Your SSL certificate is installed and working.
You need to get a secure SSL certificate,
Custom domains get a non-secure certificate automatically. (This can be used for Cloudflare I think)
