- Moderators Note -
Follow this tutorial at your own risk. InfinityFree does not recommend the modification of the control panel. Be sure you understand the risks associated with downloading and using unknown code before you do so.
In this tutorial, we will show you how to bring back cPanel Retro theme on InfinityFree’s control panel.
Step 1: Download TamperMonkey
You can download TamperMonkey here: Home | Tampermonkey
Step 2: Install the Script
Once you have TamperMonkey installed, you can install the script we created earlier to load the cPanel Retro theme on InfinityFree’s control panel. Here are the steps:
- Open this link in your browser: https://raw.githubusercontent.com/chippytech/BBCRT/main/helper.user.js
- TamperMonkey should automatically detect the script and prompt you to install it. Click on “Install” to proceed.
- The script should now be installed and active.
Step 3: Verify the Theme
Refresh the InfinityFree control panel page and you should now see the cPanel Retro theme applied. If it doesn’t work, try clearing your browser cache and refreshing the page again.
That’s it! You have successfully brought back the cPanel Retro theme on InfinityFree’s control panel.
