How to add "AddThis" sharing system to my website?
Hello.
I’m trying to add AddThis to my website, but I don’t know how to access my HTML code.
Can someone please tell me how to do it?
I’m trying to follow these steps: https://www.addthis.com/academy/how-to-install-addthis-code/
It depends on what you are using to build your website. Whatever tool you use to build your site, that’s the tool that should allow you to add any custom HTML codes.
I’m using InfinityFree’s Site Builder.
The widget to add custom HTML is listed under the Advanced dropdown.
But the instruction says that I need to add that code into my website’s HTML’s body.
More info: https://www.addthis.com/academy/how-to-install-addthis-code/
That page explains how to insert the code in an HTML website. However, you’re not using an HTML website, you’re using a site builder. Which means you need to work with the limitations of the builder.
And the builder does not have native support for AddThis, which means you’re forced to use the HTML widgets. Yes, it’s not ideal, but it’s the only option if you’re sacrificing flexibility for ease of use by using a website builder rather than writing the HTML yourself.
