How do I use MOFH?
Not a single person had even replied to a post since 15th of may in the forums of MyOwnFreeHost so I’ll ask it in this category since it’s not infinityfree related entirely
So uhh going to my domain (https://p4rty.space) just redirects to a 404 page as said in the screenshot:
No issue
Even after clearing my cache and stuff it still says 404 for me
Well it seems that your website is in a weird state
Ask iFastNet to fix it for you
It works when I use a VPN and even then the page is like unusable
You’re going to have to reach out to IFastNet’s support. This isn’t something we can help with here on the InfinityFree community forum
just use custom client, dont use native php code, it is really bad
It’s your website, and you are the hosting provider. That means you are on the hook to fix it. How do you expect to be able to run a hosting service if you don’t even know how to fix a website yourself?
It’s fine if you’re doing this as a learning project. But then try to actually learn it, and not just throw the error message over the fence and expect someone else to fix it for you.
