How do I reset phpmyadmin
Database is gone from phpmyadmin. When I click the phpmyadmin button.
I get this error and there is not database and not tables. MySQL said: Documentation
#1146 - Table ‘XXXXX.pma__column_info’ doesn’t exist
see the top Server: sql110.infinityfree.com. no database and it will not create a new one when I try to add one. below is the index.php so I can see what it missing.
Will not let me create or import.
You need to create the database in the client area, you cannot create databases in PHPMyAdmin.
