How do i put "?" there?
hello! i recently was working on this code:
include "inc/config.php";
$slot = $_GET['slot'];
$id = $_GET['id'];
$stmt = $link->prepare("UPDATE crany_cranies SET crany_slot?='0' WHERE crany_id=?");
var_dump($stmt);
 $stmt->bind_param("ii", $slot, $id);
if ($stmt->execute() == TRUE) {
    echo "You dropped item from the pet successfully";
} else {
    echo "Error droping apparel: " . mysqli_error($link);
mysqli_close($link);
i wanted to drop an item from Requested slot. but i get this error:
Fatal error: Uncaught Error: Call to a member function bind_param() on bool in /home/vol6_8/epizy.com/epiz_23744660/htdocs/dropitem.php:8 Stack trace: #0 {main} thrown in /home/vol6_8/epizy.com/epiz_23744660/htdocs/dropitem.php on line 8
i know it’s belongs to this syntax:
crany_slot?='0'
i want the “?” becomes the requested slot. but that gave me the top error. i use this and works but it’s not safe at SQL injection.
crany_slot".$slot."
How should i put the “?” symbol near to the “crany_slot”.
thank you for advise
You may need to use the following code that uses PDO instead of MySQLi Procedural to do it (in this version of the code there aren’t English grammatical errors anymore):
<?php
require "inc/config.php";
$slot = $_GET["slot"];
$id = $_GET["id"];
$sql = "UPDATE crany_cranies SET crany_slot:slot = '0' WHERE crany_id = :id";
if ($stmt = $link->prepare($sql)) {
    $stmt->bindParam(":slot", $slot, PDO::PARAM_INT);
    $stmt->bindParam(":id", $id, PDO::PARAM_INT);
    if($stmt->execute()) {
           echo "You've dropped the item from the pet successfully.";
    } else {
           echo "Error dropping the item from the pet because of a database error.";
and modify the config.php to connect to the database using PDO.
but i feel something not going true. i’ll true to fix it myself. it just gave me empty page without update
i can’t post my new code. 403?
You can post the code in a pastebin, so me and others can see it. Examples of pastebins are obviously Pastebin.com and 0bin, but 0bin is more secure and encrypted. Then post a direct link for your code stored on a pastebin.
try. thank you
