How do i enable under attack mode
https://1x337.ml
No error i just need to eable under attack mode but i cnanot do anything in cloudflare panel because it says to change nameservers but if i do that i will lose my cpanel and cloudflare is already turned on from infinity free ijust want to enable it
@admin please help
You can change your nameservers to Cloudflare after you added your domain name in InfinityFree.
If you already added your domain name to InfinityFree, you can now change your nameservers to Cloudflare.
If you enabled Cloudflare through our integration, please make sure that you’re logged in to the corresponding Cloudflare account. In the DNS Records in Cloudflare, it should say something like “managed by Byethost”.
You can also sign up for your own account and add the domain. But then those settings won’t affect your actual live site.
