https://lostnova.rf.gd
https://lostnova.space
I want the .rf.gd one to use the same files from .space
Not possible
Parked Domains support is only available for custom domains, not subdomains.
If you really need this, you could consider doing the following:
lostnova.rf.gd/htdocs directory.How about making all of the website redirect to the new domain, like example.rf.gd/somethinglikethis will change it to example.space/somethinglikethis
You can use the redirects tool in the client area for that.
You can do this, BUT NOT IF THE DOMAIN IS SETUP AS A PARKED DOMAIN!!!
If you want both websites to show the same content, you can use parked domains. If you want to move your website from your subdomain to your custom domain, that’s a different question, with a different setup.
You have two options I think:
Option 1 is cleaner, but is also more work.
