You might need to install a SSL certificate for your website to be accessible through HTTPS, even though for me it works fine under HTTPS. Anyway here’s a guide to install a SSL certificate through our Free SSL Certificates tool:
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
This article only applies to custom domains
Free subdomains (like your…
Afterwards you might need to set the SSL mode to Full or Full (strict) on your Cloudflare dashboard and force your website URL to HTTPS with this guide:
After you’ve enabled SSL for your website, you’ll probably want to redirect all traffic on your website to the https version of your site. There are multiple ways to do that. Let’s compare some commonly used ways.
Using script configuration
Some scripts (including Wordpress) have a setting which allows you to set your website URL. By changing this URL from http://example.com to https://example.com , the script will probably redirect visitors to the https version of your site. Even if your script…
system
Closed
January 17, 2025, 5:12pm
3
