xmiwng
1
When I use Moodle, sometimes I see this error:
Exception - Call to undefined method IntlCalendar::setGregorianChange()
When I get some research, it says me to configure and change some data in the php.ini file, but InfinityFree doesn’t allow users to access it.
Then how can I solve this problem? Please help me!!!
dan3008
2
Unfortunately, this is probably the wrong place to ask.
If the fix requires changes the php.ini file, then you can’t fix it.
all I can suggest is reaching out to moodle support to ask them for some guidance, and see if there’s an alternative fix.
xmiwng
3
oh okay lemme ask them, tks
system
Closed
4
