Hosting Issue and Domain
lelandev.22web.org
It is not loading for me at all
404!!
Been having issues
If you are willing to help me out contact me on discord as it will be easy to stay in touch thank you!
Hidden by MOD - PII
Hi and welcome to the forum
Please read ( home directory, etc.)
Please Give me a second as a read it and did not understand it.
Check the home directory of your domain
In the Domains page of your account in the client area, you can find the domains of your account and the folders on your account they are linked to.
Please make sure that the domain folder listed there actually exists on your account (every URL will redirect to a 404 page if the domain’s website folder is missing), and that you uploaded your website files to that directory.
What dose this mean?
use lowercase letters (rename it) - the server is case sensitive
How long should i wait to see if it up now?
As i am stilling getting the same error
you corrected it and now it works but,
now you have to upload the index file to htdocs
Please clear the browser cache by pressing a few times Ctrl + F5 while viewing your website.
If that doesn’t help (because some browsers are stubborn) then follow these instructions
How do i connect a index file?
shut down monsta FTP
and turn it on again
go in lelandev.22web.org dir
inside this folder you will have htdocs
in that htdocs you should have (upload) an index file
Where is monsta?
I cant not view my file now for uncaping the L
I shut down Monsta
Here is where i put the index?
it’s that online FTP client you took in your last screenshot…
that’s why I say turn it off and then go to the client area
there you have a domain section (click it)
call FILE MANAGER there again
yes if this is TRUE
The sytem blcked me for 24 hours so now i am using this
we are in PM
online test WebPageTest Test - Running web page performance and optimization tests...
I’m going to sleep - for all other questions regarding the maintenance and creation of the site, logo, etc. ask here…
in short, the user had page1.html instead of index.html
and .index without extension and hence the problem except for the original 404 from ifastnet because he changed the dir name ( capital letter L)
@anon1359470
btw.
How to Name Files/folders
Do Not Use Special Characters
For best results, you should only use the letters a-z, A-Z, the numbers 0-9, hyphens (-), underscores (_) and periods (.). Any other character could get you in trouble, causing the file not to load or the page to load incorrectly.
it is best to use lowercase letters, also Do Not Use Any Spaces
