Hey People my laptops battery broke and was replaced my laptop had to be opened
Hey People my laptops battery broke because the battery was swollen and was replaced my laptop had to be opened, I backed up my stuff on external hard drive, will see if the new battery works better, all of those screws hard to remove
which laptop model do you have
I have Dell Inspiron 7591 that’s my model, the last battery lasted 3 years
3 years is pretty good, I hope your new battery lasts well
that laptop is one of the nicer ones to change a battery, just a few simple steps
  • remove the bottom panel screws and panel
  • carefully remove the battery connector from the socket on the motherboard
  • remove the battery screws and battery
  • pop in the new battery and screws
  • plug in the new battery cable to the motherboard
  • put the bottom panel on (no screws yet) and test to make sure its working
  • if all is good then screw the bottom panel
I recently changed a battery for a customer with a gaming laptop that that was a real headache
I had to disassemble the whole laptop to pieces because the battery was buried inside :frowning:
Oh one more point I forgot to say
Some laptops (im not sure if this applies to this model) you find that after changing the battery and switching on you just get a black screen !
This can look like something is wrong but don’t panic as a lot of laptops will show a black screen for maybe a minute while they reconfigure themselves but eventually you should see the usual boot logo appear
This has caught me out a few times especially on laptops that have no power leds :rofl:
I did not get a black screen :slight_smile:
Don’t you miss those times when removing the battery was as simple as pulling two latches at the bottom and the battery popped out?
I’ve got a 10 year old laptop that has one slider switch for battery release!
I had Asus laptops and they broke really easily, and even on warranty they didn’t won’t to repair them so I move to Dell, My Dell works like new again :slight_smile:
I’ve got a toshiba L50-b from around 2014, bought it 2nd hand for less than £50
It still has the original battery and it still runs for about 3 hours on battery power
I got really lucky
It looks just like this but with Linux Mint instead :wink:
oh and mine now has a black trackpad as the original white one de-laminated during the hot weather and had to be replaced
Doesn’t that mean you’ll also get the Ubuntu snap stuffs? :thinking:
Why not LMDE :stuck_out_tongue:
snap is not installed and is disabled in linux mint but you could enable it if you’re feeling dangerous :stuck_out_tongue:
Returning on topic, the last laptop I had before I switched to a MacBook was a Lenovo Ideapad 100-15IBD from around 2015, which my dad now uses; probably a laptop made when changing the battery pack was a bit harder than just releasing a lever.
I surely miss the times where I had to release a lever to unmount the battery pack (but I also had two other laptops from Acer which had that system as well)…
My own laptop is a 12 year old Samsung Chronos, Core I5 etc.
Still got the original battery that lasts about 3-4 hours with moderate use.
Still running Windows 7 - Can’t even remember when that was last updated.
It does everything I need. Just hope it doesn’t expire before I do
:smiley:
At least with these laptops the battery isn’t glued in like a macbook :face_with_symbols_over_mouth:
I hate those things. Done so many and its never easy, Isopropyl alcohol, plastic pry tool and a lot of hard work :frowning:
I have an old Commodor64 I also have an old Sanyo CRT tv and games for it on a MicroSD 64 GB card. Commodor64 works really well
How I wished I had a Commodore 64 and still had an old CRT as well…
Of course Apple has to use super-strong adhesives to keep batteries safe!
