I accidentally deleted the htdocs folder from my file manager. Is there anything I can do to get it back ? Thank you.
Unfortunately, there isn’t. You can recreate it and reupload your website contents there, but if you didn’t have a backup, they are lost.
Thank you so much for your quick response. The folder was actually still empty, I was having sizing issues. I was deleting what I had loaded and hit the one folder I didn’t want to. If I recreated the htdocs folder it would work?
Yup. There is nothing special about that folder except its name.
Thank goodness. I was sure I broke it. Could not see any fix. Thank you.
