I downloaded my mysqldatas and my website and I fixed and customized the whole site on the localhost xampp, I uploaded the website and now when i try to upload mysql data I’m gettin ERROR. I deleted the old base and created the same , changed everyting in config.php the details but When I try to upload the mysql database it happens this
Which might suggest that you took so much time modifying on local XAMMP and your session expired.
Just go back to Control Panel and re-enter phpMyAdmin then try again.
Or maybe your file is too large and the session expired half-way — if this is the case you have to find a way to split the SQL file into chunks; I would suggest import a table at a time instead of a whole DB.
When I try to upload this table wpdj_options then it gives me the same EROR As the image where I posted all otheres tables are imported succesfully do you have any ideas why this cannot be imported. Also on the site I’m getting thiss ERROR , THIS IS THE WEBSITE : https://skingsofficial.is-great.org/
