Help
How would I use images in my html code
w3schools is a great resource for all things html, click the link below for info on img tags
Thank you kind sir
Another question is it good to use wordpress code on a website here or better to use a plugin for wordpress because I don’t want the banner so
wordpress runs well on infinityfree but im not sure what you mean when you talk about the banner ?
can you give details, thanks
Could I use other websites html
What do you mean by “other website’s html”? You may run into copyright issues unless of course the owner of the “other website” said ok.
And if you cannot describe your problems clearly and only wanted to act like you are using a social media app, then unfortunately your problem is never gonna be solved, as nobody can really understand it.
I mean like a wiki website could I. Copy the html from that and my word press website so that I could combine them here
No, you can’t copy someone else’s code without permission, that’s illegal.
Thx for letting me know
How many users can infinity free handle at once on my website using the free plan
That all depends on how many resources your website is using. Please learn more about the limits in the Fair Usage Limits.
Also dose infinity free have support for firebase authentication integration
And where do I check website statistics
If you using wordpress you need to try the plugin Site Kit By Google.
Just normal html
in your cpanel you can find stats
Thx
How do I use fandoms wiki page of something like ark source code in my Website
I don’t understand what you mean by this.
Fandom is a hosted wiki platform, originally built using the MediaWiki software. MediaWiki is free PHP software, and can be found in Softaculous, but MediaWiki has gotten so big that you may not be able to install it without hitting the inode limits.
I don’t know what “ark source code” is, so I have no idea what it has to do with websites.
