Help!
aahomebuyers.rf.gd
Hello,
I hate to bother you but I had a stroke and a heart attack. And I need help in figuring out what went wrong. I had Directory Listing and that is all.
Duff
What was there before?
Sorry to hear that, but hope you’re ok!
So sorry to hear that happened, I hope you are doing OK!
The reason your website is showing a Directory Listing is because you don’t have an index file. An index file can be named index.html or index.php.
By chance, do you remember if you are using a script on your site? Or did you self-code it?
I don’t really understand your full problem, do you think you can expand on it? Thanks.
default.html is the code.
One other thing, Microsoft Expression Web 4.
Add this line to the .htaccess file in your htdocs folder:
DirectoryIndex default.html
Is this the software you’re using? Remember, the only backend scripting language we support is PHP. Microsoft tends to use ASP.
Yes!
It won’t do it. What am I doing wrong?
Make sure to add in the htaccess inside the /htdocs directory.
I don’t know to do it?
I have already done that, FTP. I want to know how?
Duff
How to do what? @jaikrishna.t told you to upload to /htdocs, and you said you don’t know how. All you have to do is connect via FTP and upload the files to the /htdocs folder. The article tells you how to do that.
It would seem your website files are incomplete. Normally, the base folder of your website needs to have an index.html file.
How are you uploading the files by the way? Are you uploading them manually with FileZilla or something like that, or does your website builder have tools to automatically push your site to our servers?
If it’s the former, please double check that the folder with your website files has a file with the name index.html in it.
Hello,
default.html. And I’m using FileZilla.
No such file
Can you please upload all of the files again? It look like you still have some missing.
It’s still not working.
Of course it is not working.
Do you mean this???
If so you need to have default.html in /htdocs directory and rename it to index.html
Ok, will do.
