Exactly what it says. Right now your trust level is “new user” so some functionalities of the forum are very limited for you. Once your trust level is “member” you’ll have some less restrictions.
Keep interacting with people on the forum and your trust level will go up in no time.
You can also gain trust by reading things on this forum, too!
I would suggest reading this first: Guidelines/Forum Rules
After reading all of that, you could read some documentation, some community guides, maybe even find an answer in an existing hosting support topic!
Enough reading helped promote my Trust Level to Member!
