This site can’t be reached
swpaste.infy.uk took too long to respond.
Try:
- Checking the connection
- Checking the proxy and the firewall
- [Running Windows Network Diagnostics](javascript:diagnoseErrors())
ERR_CONNECTION_TIMED_OUT
Try:
Working straight away for me
Next thing to check would be if it’s being blocked by either a firewall on your computer, or your isp may be blocking the site. Does it work if you use the different device on a different network such as your mobile on mobile data?
Please note that while pastebin services are not banned, you are fully responsible for everything people upload to your site - and will be held liable if someone decides to post illegal or adult content.
Check if your ISP is blocking the website or Infinityfree/IFastNet servers. If your ISP is not maybe infinityfree blocked your IP, try to go to the website on a different network and different network use mobile data. If this all don’t work just use a VPN or wait for your ISP to charge your IP.
