okay now can you see if my files for mybb and everything is installed correctly please I am logged into my file zilla on my desktop not sure if I uploaded them correctly and can u make sure my domain is sett up also.
I did have a quick look at your account. Your website seems to have a single “hello world” PHP file, which is also what I see when I visit your website, and there doesn’t seem to be anything else.
I don’t see any traces of a MyBB installation, except for the internal bookkeeping of the MyBB website you deleted before.
What did you expect to see at this point?
If you want to install MyBB, you can either upload it yourself or install it through Softaculous. And using Softaculous is the easy option.
You should upload it to the Htdocs folder. But if you use the script installer it will be a lot quicker and easier since that’ll set up the SQL database too
