Help with MySQL
epiz_29508318, itlxajzn.epizy.com or https://www.chrissquartz.cf ( my own custom domain )
None
I am a total beginner at mysql, and How would I query data from mysql ( i have made a database, table and row ) how would i get the data that’s in the row? I’m using it to store a password ( so php and then have javascript use the data gotten from php ), If you need anything else just ask
What are you going to use it for? Google has many tutorials out there, so take a look!
I have a password protected page and right now the password is just in plain javascript and i would like to make it a bit harder to get in, and i thought of using mysql to get the password from a database, I have a button that calls the javascript function
this night help: MySQL - Select Query (tutorialspoint.com)
I’ll have a look at it thanks
sure!
You can alternatively use the “Directory Privacy” feature in the control panel. It’s the most secure way, but you don’t get a pretty login page.
