I just renewed the domain on name cheap, how do I connect the servers back up to my old website which is hosted through infinityfree?
Follow the same steps
is this for if your connecting the same website?
What’s your domain?
If the nameserver settings on your domain is changed during renewal, then you have to change the nameservers back. You don’t have to do the last few steps to add the domain as long as you still have the domain on your account.
my domain currently is quartztag.com , I just renewed it, I use cloudflare aswell, but website is not up I just renewed it yesterday, should I wait or is something changed?
For me your website works fine if this is what you used to get before renewing your domain:
You might need to wait for DNS propagation or follow the workarounds on this article if it still doesn’t work on your side:
Hmm, thats interesting cause it doesn’t work in my end. Thank you I think I might wait then if it is working
