Help on dns
I get an error when I set my domain’s DNS to Infinity Free. This is what I get when I connect to Blogger. It tells me that the test data is not visible on the public internet. What test data? I don’t understand. I’ve checked my DNS several times and still nothing. Does anyone know what the errors are? Please.
pagina
Hi and welcome to the forum! Please decide which hosting provider to use; that screenshot is only related to Blogger’s SSL certificate, so if you want to use Blogger please change your nameservers back on your domain registrar’s DNS panel and point your domain with a CNAME record to the record(s) they’re telling you to use.
I am pointing the blogger servers “ghs.google.com” to infinity free. I transferred my domain to another provider. But my domain provider tells me to give them the names of the hosting servers where to point the domain, and I gave them infinity free. Or do I have to give the blogger servers to my provider?
I put the CNAME that blogger gives to infinity free. But it is not working. Previously it was working on my cell phone but on the computer it does not enter or my domain does not work.
What are you trying to do exactly, and where are you getting these errors?
Both Blogger and InfinityFree are website hosting services, and you can only host a website with one provider at a time. So if you want to host your website with us, you probably shouldn’t have any Blogger settings on your domain, and if you want to host it with Blogger, then you shouldn’t have any settings from us.
If you can tell us a bit more about what you’re trying to, we can tell you what to do. And if you could share the domain name on which you’re trying to set it up, we can confirm whether your settings are correct.
