Help me
Hello! I need to verify domain ownership rights. I am casting .html file with a verification code to the server via FTP. Then I press the button “check domain ownership rights” and in return get the error “file on the server code is not correct.” Posted in support, they sent the error code:
A Support:
"Your site meets like this script, instead of the desired page.
function toNumbers(d){var e=[];d.replace(/(..)/g,function(d){e.push(parseInt(d,16))});return e}function toHex(){for(var d=[],d=1==arguments.length&&arguments[0].constructor==Array?arguments[0]:arguments,e="",f=0;fd[f]?"0":"")+d[f].toString(16);return e.toLowerCase()}var a=toNumbers("f655ba9d09a112d4968c63579db590b4"),b=toNumbers("98344c2eee86c3994890592585b49f80"),c=toNumbers("f8fb47913b933a6a6be778a06d325f11");document.cookie="__test="+toHex(slowAES.decrypt(c,2,a,b))+"; expires=Thu, 31-Dec-37 23:55:55 GMT; path=/"; location.href="http://cinemaon.ga/682970.html?i=1";This site requires Javascript to work, please enable Javascript in your browser or use a browser with Javascript support
I think it’s because of JavaScript? Javascript is disabled on hosting? and how to enable it?
I think JavaScript is disabled on the host. Is it possible to enable this feature?5856d1e821a96.png
Javascript is a programming language which runs primarily in web browsers. The error message you’re seeing is not caused by missing server software, it’s caused by your browser not running javascript.
