Help me with ads.txt
Hey i applied for an ad monetization website and they asked me to create an ads.txt
and i did but it is till showing error
so can you tell me if i did it right
thriftyblogs.site/ads.txt
As mentioned previously, Ezoic doesn’t work well with free hosting.
In any case, the reason why you’re getting an error is this system:
As mentioned in the previous topic which you opened for practically the same question:
Your site seems to still be using InfinityFree’s nameservers:
I’d recommend following the process in the tutorial mentioned in the previous topic to connect your domain to Cloudflare, and then trying the validation of ads.txt once more.
Keep in mind it may not work, though, because as far as I’ve seen on this forum no one has been able to get their site to work correctly with Ezoic.
