I am setting up flarum for my forum while setup it asks for my sql database please someone help me
Hey there,
What help do you need? And are you trying to setup this on a domain or a subdomain?
Best Regrads
Hello!
Please provide an error message or add a message, you need more details
Best Regards
As the above people have said, That look’s good, and is your error that you can’t connect, or rather that you have issues filling it in?
We are sorry, but flarum is something that free hosting doesn’t support.
Better look for other php forums!
You need SSH access to install it. I know you are illegally installing flarum.
You can make a free flarum here: https://www.freeflarum.com/
And then (if you have a domain name) create a cname and have your forum something like forum.yourdomain.com
wow, very informative, thanks for sharing this!!!
(i will probably use it soon)
Oh ye, and thanks! I am going to use it for documentation! (docs.hn.fyi)
Yeah that’s great.
No problem Love helping !
hello sir i used xamp and got all those files in my pc and uploaded those files in my server i just need to setup the sql.
i am trying to setup this in my subdomain i dont know what to enter in database name and table prefix.
Hey,
You can create databases from MySQL databases. Add the name of the database you create where db name is needed. You can leave blank the prefix.
Hope that this helped
yeah i created the db name and entered correctly but it still says error i will try again and tell
Table prefix is a sign added before table name. For example in bd_table
table, bd_
is its prefix.
Database host is not localhost. See the mysql server in your cpanel. That’s the problem probably
Also, When installing extensions, you will not be able to, as Flarum requires (as someone said) ssh to use composer to install sutff
ssh and composer is used here to get the files and unpack and make it has a setup but i already done it
