i am new to all this stuff, and wanted to this domain to point to my ip address of my home server, i was told i need to edit the a record and add my ip there but i don’t know where a record is and how do i edit it please help.
Hello there,
You cannot edit the A records for that subdomain.
Currently there’s no option to edit A records for domains here as well.
Hello, if you want to do this, you will need to buy a domain (.com is about $10 a year, I recommend NameCheep), and point it to Cloudflare using the domain’s nameservers. In Cloudflare, you can create an A record pointing the domain to your home server.
Good Luck!
