Help 403
Username or Website URL
simnetwork.tk
403 Access denied
hi I just started my site on infinityfree
when i go to the site (simnetwork.ga) it says access denied … someone can help me?
Please wait for 24 hrs due to DnS propagation
ty for the fast response
ill wait
Which is your domain exactly?
.tk is banned so probably simnetwork.ga
i have simnetwork.tk that redirects to simnetwork.ga
your website doesn’t point to our nameservers, please change them to ns1.epizy.com and ns2.epizy.com
Yes it is
It does not.
i just checked
It isn’t changed yet.
idk freenom is dumb
now is changed but i have the same error
Wait for some time!
ok sorry
I checked, But get no response from your nameservers, Have you added your domain as an addon/parked domain? Your clearly on our hosting system, But you need to assign the domain name
when i started i clicked on use your custom domain and put the domain
Can you show me a screenshot of the domain added in your vPanel?
Did you check your index.html/index.php? Check it by going to the Filemanager, and go to the htdocs folder. Open the index and share what it says.
