I am having trouble with uploading private key and ssl certification in my cpanel. When even i paste private key and click upload. After upload I can’t see any private key.
Welcome to the forum!
Can you please fill out the topic template next time?
I am going to need the SSL provider you are using to get this certificate.
Also, can you follow this guide and let me know what step you are stuck on?
Its Lets Encrypt SSL Certificate from infinityfree ssl certificated.
I had followed these steps but I am having trouble with uploading certificate in my cpanel.
What error are you getting?
When I go to my cpanel and open ssl and then click on configure. I have 3 Sections for Private Key, CSR and Certificate.
I paste the private key in empty box of private key section and then click on upload. After page refresh the private key box remains empty.
Yes, that is a know issue, they may be doing maintance.
OK then how much time will it take?
It looks like it is already back up again
Now I can Login to cpanel. But
This problem is still present.
Try…
- Clearing your cache
- Using a different browser
- Using a VPN
