Hello,
I was finally able to get myBB working with smtp@ gmail. It seems that since I am a new member of this message board, I am not allowed to post anything but 2 links… Check out my solution here.
Inserted external content into the post by moderator
Hello,
I’m an IT Tech but I am new to MyBB, please keep that in mind.
I have searched through the net and did not find anything to help me get setup with MyBB hosted on Infinity Free, using Smtp.Gmail.Com.
Here is what I did.
- Configure your Google profile (the one used for sending SMTP email from MyBB) with 2 factor authentication.
- Go to google App Passwords in your Google profile properties.
- Add the app name smtp.gmail.com and copy the generated password.
- Configure MyBB Admin CP> Configuration > Mail Settings. Add the following details;
-Mail Handler: SMTP
-Smtp Hostname: “GMAIL HOST”
-Smtp Port: 587
-Smtp Username: [email protected]
-Smtp Password: “The generated App Password from Google”
-Smtp Encryption Mode: TLS Encryption
-Save Settings.
**When I had my admin Email Address configured as the same as my [email protected] it would not send out emails. I switched it for another @outlook.com address and it seemed to resolve the issue. **I honestly cant say if this step is necessary or not… As is said, it seemed to work for me.
Note: The quickest way I found to send an email in MyBB is to go back to the forum and select a thread, Then select “Send this Thread to a Friend”. The message should arrive promptly.
**If it does not work; I suggest you use this SMTP tester. SMTP Tester
In the tester page;
-Select all the available options and enable logging, Your error should be clearly listed in the log.
